convert code From Lisp to C-Sharp
hosneyalaa
Advisor Advisor
hosneyalaa
Hi how can convert
This code is from  @Jeff_M
https://forums.autodesk.com/t5/civil-3d-customization/create-cogo-point-using-lisp/td-p/8960247
(setq C3D (strcat "HKEY_LOCAL_MACHINE\\"
			     (if vlax-user-product-key
			       (vlax-user-product-key)
			       (vlax-product-key)
		 C3D (vl-registry-read C3D "Release")
		 C3D (substr
		       C3D
		       1
		       (vl-string-search
			 C3D
			 (+ (vl-string-search "." C3D) 1)
to get the number for example  "13.4"
I came close to it, I did not know the origin of the solution
https://www.theswamp.org/index.php?topic=43276.0
// I got the "Software\Autodesk\AutoCAD\R19.0\ACAD-B001:409" value:
String _x = AcDb.HostApplicationServices.Current.MachineRegistryProductRootKey;
String _y = AcDb.HostApplicationServices.Current.UserRegistryProductRootKey;
Jeff_M
        /// <summary>
        /// module must be "Land", "Pipe", "Roadway", or "Survey"
        /// </summary>
        /// <param name="module"></param>
        /// <returns>AeccApp string</returns>
        public static dynamic GetAeccApp(string module)
            var rootkey = HostApplicationServices.Current.UserRegistryProductRootKey;
            var hj = Registry.LocalMachine.OpenSubKey(rootkey);
            var c3d = (string)hj.GetValue("Release");
            c3d = c3d.Substring(0, c3d.IndexOf(".", (c3d.IndexOf(".") + 1)));
            hj.Close();
            c3d = "AeccXUi" + module + ".Aecc" + (module == "Land" ? "" : module) + "Application." + c3d;
            dynamic acadApp = Application.AcadApplication;
            dynamic aeccApp = acadApp.GetInterfaceObject(c3d);
            return aeccApp;
hosneyalaa
@Jeff_M
Thanks a lot
