Cogopoints dynamic aspect to Surface
DRossger
Message 1 of 15
DRossger
Hello!
I have written som net-functions which can put out Cogopoints on 3dPolyline or Featurelines and also can interpolate between them. My question is, if it could possible to set dynamically Cogopoints to a Surface. So elevation can change in touch with a Surface ?!
Replies (14)
Message 2 of 15
Jeff_M
Yes, that can be done with a fair bit of coding. We have this option in the DLPoints command of the Sincpac-C3D add-on. Any number of points can be dynamically linked to a surface.
Message 3 of 15
DRossger
Sorry Jeff for delay. Thanx for your reply, I have to check this,  your shoulder is my best support.
Message 4 of 15
Civil3DReminders_com
These series of posts is a good example of how to set the framework up.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Message 5 of 15
DRossger
dlpoints is not available in trial - i am said
Message 6 of 15
Jeff_M
If you are talking about of DLPOINTS in the Sincpac-C3D addon, it most certainly is available in the trial. The trial includes ALL of tools, not just a small sampling.
Message 7 of 15
DRossger
Yes Jeff my fault.
Now I was testing dlpoints, but not getting right, because CogoPoints will not update.
Certainly I prefer CogoPoints that creates has allready integrated the Linkoption (Elevation <- -> Surface) not after.
I have seen if rightclick on CogoPoint-object I can choice "Elevation from Surface...". Is that a metod I can get with .net too?
Message 8 of 15
Jeff_M
You can easily get the elevation of a surface at the CogoPoint location, although it's not a built-in method. Creating an extension method would not take too much work.
Message 9 of 15
DRossger
if I understod you mean creating cogopoints with findelevationXY metod, in this case cogopoint-elevation is not linked and not changing if move position or?
Message 10 of 15
Jeff_M
Correct, it is not linked. To create a link, as we have done in the DLPOINTS tool, requires a lot more work and involves the use of various events to track the edited point or surface and update the points when needed. Not a trivial task, but the links @Civil3DReminders_com provided previously will help get you started.
Message 11 of 15
anhtrung
Do you want just that you need in Video below?
Message 12 of 15
DRossger
Exactly, great done. I'm nice inspired of your work. Thank you!
Message 13 of 15
anhtrung
Do you want try my apply?
If just that you need i can send app for you.
Message 14 of 15
DRossger
Great that would be fantastic ! /D
Message 15 of 15
anhtrung
You must to send email from to me that i will send file .exe to you.
