Civil3D 2013 COGO Point update User defined property value using C#
Hello All,
 I need to update the user defined property values using C# code,
I can see information on how to ge the values of UDP but cannot see any information on how to modify, edit, udpate or add infromation to the UDP of a point.
Basically in the attached image i want to add "Street light" to the Type UDP.
Please advice
Jeff_M
If this doesn't help, show code you are trying.
cogopt.SetUDPValue(udpname, udpvalue);
Hi Raghulan,
You can use CogoPoint.SetUDPValue
You can see some related code snippet in ADN IM DevBlog -
http://adndevblog.typepad.com/infrastructure/2012/08/set-parcel-userdefined-property-from-api.html
http://adndevblog.typepad.com/infrastructure/2013/04/civil-3d-net-api-cogo-point-how-to-read-a-user-...
Let me know if you have an issue using CogoPoint.SetUDPValue() API Hope this helps !
Cheers,
Partha
Thanks Jeff, will try and update!
Thanks Partha, Will try and update.
Here is the code to help someone else
public static void udpate_UDP(CogoPoint cogoPoint, string udp_classification, string ud_prop, string value)
            try
                UDPClassification udp_class = set_udp_class(udp_classification);
                if (udp_class != null)
                    UDPString udp_string = null;
                    Global.variables.ed.WriteMessage("\nClassfication: " + udp_class.Name);
                    foreach (UDP udp in udp_class.UDPs)
                        if (udp.Name == ud_prop)
                            //UDPString udp_string =
                            //udp_string = udp.Name;
                            udp_string = (UDPString)udp;
                            cogoPoint.SetUDPValue(udp_string, value);
                else
                    Global.variables.ed.WriteMessage("\nClassfication NOt found or incorrect: " + udp_classification);
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                Global.variables.ed.WriteMessage("\nError : " + ex.Message);
 public static UDPClassification set_udp_class(string udp_class_set)
            UDPClassification udp_class1 = null;
            try
                if (Global.variables.cdoc.PointUDPClassifications.Contains(udp_class_set))
                    foreach (UDPClassification udp_class in Global.variables.cdoc.PointUDPClassifications)
                        if (udp_class.Name == udp_class_set)
                            udp_class1 = udp_class;
                else
                    Global.variables.ed.WriteMessage("\nUDP Classification Dont exists! ", udp_class_set);
                    udp_class1 = null;
            return udp_class1;
