Can't get 'AddTinVolumeSurface method to work.
tcorey
Mentor Mentor
Message 1 of 8
tcorey
I am at my wits end.
Trying to create a Tin Volume Surface using Vlisp.
The Surfaces collection has a method called AddTinVolumeSurface (1). The (1) meaning the method takes one arguement, right?
Here's the code:
(setq surfs (vlax-get-property c3ddoc 'Surfaces))              ;sets the Surfaces collection as surfs
;(setq surfname (vlax-make-safearray vlax-vbstring '(0 . 0)))   This was an attempt to use a safearray of a single dimension
;(vlax-safearray-fill surfname (list "tempsurface"))   and fill it in with a list.
  ;(setq surfname (vlax-make-safearray vlax-vbstring))   Tried it without the dimensions of the array
;(vlax-safearray-fill surfname "TEST"))                   Tried filling the array with a string instead of a string in a list.
  ;(setq surfname "TEST")                                     Tried with the surfname set to a string, not a safearray.
  (setq surfname (vlax-make-variant "TEST" vlax-vbstring))        and the most recent try, using a variant.
(setq surf3 (vlax-invoke-method surfs 'AddTinVolumeSurface surfname))   But when I use this code to create the surface, I get various errors, depending on the option I used creating surfname.
What is expected from AddTinVolumeSurface (1). I am putting the surface name in as an arguement, but I can't get it to work. I have tried integers like 0 and 1, I have tried T and F. I really wish there was documentation somewhere that would tell me what is expected here .
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Replies (7)
Message 2 of 8
Jeff_M
You have to use the COM documentation, Tim. From THIS page you will find you need to pass a TinVolumeCreationData object. Here's some sample code I was playing with a few years ago for a TinSurface. You will need to make appropriate modifications for the TinVolumeSurface and newer versions of C3D. The difference in the TINVolumeCreationData being you also need to set the 2 comparison surfaces.
(vl-load-com)
(setq prod (vlax-product-key))
(setq verstr (cond ((vl-string-search "\\R18.0\\" prod)
		    "7.0"
		   ;;2010
		   ((vl-string-search "\\R18.1\\" prod)
		    "8.0"
		   ;;2011
		   ((vl-string-search "\\R18.2\\" prod)
		    "9.0"
		   ;;2012
(setq prodStr (strcat "AeccXUiLand.AeccApplication." verstr))
(setq datastr (strcat "AeccXLand.AeccTinCreationData." verstr))
(if (and (setq *acad* (vlax-get-acad-object))
	 (setq C3D (vla-getinterfaceobject *acad* prodStr))
	 (setq C3Ddoc (vla-get-activedocument C3D))
	 (setq surfs (vlax-get C3Ddoc 'surfaces))
	 (setq tincreationdata (vla-getinterfaceobject *acad* datastr))
  (progn
    (vlax-put tincreationdata 'baselayer "0")
    (vlax-put tincreationdata 'layer "0")
    (vlax-put tincreationdata 'description "Surface from Lisp")
    (vlax-put tincreationdata 'name "Lisp EG")
    (vlax-put tincreationdata 'style "Border Only")
    ;;style must exist!
    (setq
      surf (vlax-invoke-method surfs 'addtinsurface tincreationdata)
    ;; do whatever else is needed
    (vlax-release-object tincreationdata)
    (vlax-release-object surf)
    (vlax-release-object surfs)
    (vlax-release-object c3ddoc)
 And here's the LINK for the general COM help.
Message 3 of 8
tcorey
Aha. COM documentation. That's gonna be the ticket. I''ve been flying blind and you just removed the blindfold.
Thanks, Jeff. Next time I see you I owe you a keg of beer for all your help!
Tim
Tim Corey
Redding, CA
Message 4 of 8
tcorey
I am trying to create a TinVolumeSurface and the put-property method is not working for the base surface name;
This line works, fills the baselayer property correctly
(vlax-put-property tincreationdata 'BaseLayer "TEMPORARY-FOR-VOLUME-CALCS")
This line gives me a type mismatch
     (vlax-put-property tincreationdata 'BaseSurface "Surf1")
I have tried using a string as above, tried pointing to the actual surface object:
 (vlax-put-property tincreationdata 'BaseSurface surf1)
Tried pointing to the surface Object id
 (setq surfobjid (vlax-get-property surf1 'ObjectID))
(vlax-put-property tincreationdata 'BaseSurface surfobjid)
 As you can see, the tincreationdata object is being created and the BaseLayer property is accepting the put:
(vlax-dump-object tincreationdata)
; IAeccTinVolumeCreationData: AeccTinVolumeCreationData interface
; Property values:
;   BaseLayer = "TEMPORARY-FOR-VOLUME-CALCS"
;   BaseSurface = nil
;   ComparisonSurface = nil
;   Description = ""
;   Layer = ""
;   Name = ""
;   Style = ""
I can put the description, layer, name and style, too, just not the basesurface and comparison surface.
Thanks for any input...
Tim
Tim Corey
Redding, CA
Message 5 of 8
Jeff_M
Gah! I knew I should've checked before posting. Sorry Tim, this looks like one of those things that lisp just won't do. It can be done in VBA & .NET, but lisp doesn't pass the correct object type to the tinvolumecreationdata surface properties.
This is the same issue when you try to do this:
(setq surf1 (vlax-invoke-method surfs 'item "Surface1"))
It will error with "type mismatch" so you need to loop through the collection to get the surface you want:
(vlax-for surf surfs
      (if (= (vlax-get-property surf 'name) "Surface1")
	(setq surf1 surf)
	(if (= (vlax-get-property surf 'name) "Surface2")
	  (setq surf2 surf)
 I don't see a backdoor method of passing the correct object type. So it looks like I led you astray on this one, Tim. Sorry about that!
Message 6 of 8
tcorey
There's no reason to apologize, Jeff. You have helped so many community members. You're entitled a small mistake once in a while. I only spent an hour or so on it, so no biggie.
It looks like I'm just gonna have to knuckle under and learn c#. Peter Funk has stated it here, emphatically, several times, that .net is the way to go. I guess I should listen.
Mostly, I'm gonna miss being able to debug on the command line. ;-(
Have a great day and thanks for all you do, Jeff.
Tim
Tim Corey
Redding, CA
Message 7 of 8
Hi Tim & Jeff,
Sorry to be late on this issue....
Few releases ago I had looked into this and my approach was this :
;(vlax-put-property oTinData 'BaseSurface oSurface1)
;(vlax-put-property oTinData 'ComparisonSurface oSurface2)
(setq oVolTinNew (vlax-invoke-method oSurfaces 'AddTinVolumeSurface oTinData))
However, I think we had an issue here in using Civil 3D COM / ActiveX API in LISP call. And I had seen some other areas too where it doesn't work and hence I would suggest to move on to use Civil 3D .NET API.
Partha
Message 8 of 8
tcorey
Thanks, Partha. It seems that's the way I'll have to go....
Tim Corey
Redding, CA
