c3dreports GetStationStringWithDerived is not a member
Message 1 of 10
Civil 3D 2014
I need to edit some items in the Report facility. Found the VB dot net source code under:
C:\ProgramData\Autodesk\C3D 2014\enu\Data\Reports\Net\Source
Opened it in Visual Studio 2013 for Windows Desktop
Set the paths of the references.
Set the build to a different folder.
On Build Solution there is a long list of this error:
GetStationStringWithDerived is not a member of Report.ReportUtilities
Looks like the source provided to users is not the actual source - correct?
How do I correct this error?
I am much more proficient in C#. Is the reporting source project available in C#?
I was considering using Autodesk support to make a support request for this problem. But this kind of request is probably not covered by standard support - correct? If I want Autodesk support for this kind of problem I probably need to be a member of the ADN - correct?
All I really want is to solve the GetStationStringWithDerived method error and continue to edit the source.
The other questions can be ignored. I just got carried away.
Thx for reading,
Cheers for now,
Kevin.
Replies (9)
Message 2 of 10
Jeff_M
The reports have always been finicky when loading them the first time. I recall running into this, but not sure what, exactly, I did to correct it. The function IS in the code (I just checked the installer and it's all in there) but I see that I have modified the ReportUtilities module since installing so I had to have done something...I'm just not seeing what that might have been in a quick look.
Yes, it's now late here (11:30 p.m., California) headed for bed now. Smiley Happy
Message 3 of 10
Hi Kevin,
I did a quick try using Visual Studio 2012 and it seems to be building the "C3DReport.dll" without any issue.
What's the targeting .NET framework you selected in Visual Studio 2013 ?
Message 4 of 10
4   ... tried targeting to 4.5 and 4.5.1 ... same error ...
Plus ...
The error message is correct on my side. On my side ReportUtilities.vb does not include a method named GetStationStringWithDerived.
This method is used about 100 times.
Does your ReportUtilities.vb include a method named GetStationStringWithDerived?
If so .. then I have the incorrect source code ... would be great if you could make it available somehow (not just ReportUtilities.vb , the entire Project).
Thx for the asistance.
Message 5 of 10
Hi Kevin,
I can arrange to upload this, but I am wondering how the source could be different in your installation ?
How about others ? Could anyone rebuild this source successfully ?
Partha
Message 6 of 10
tyronebk
No problems here. Copied source to a writable location, added a reference path to resolve references, build, done.
Message 7 of 10
Looks like I have the incorrect source.
Would be great if someone could zip it, upload to cloud, make public and share ..
please ...
Thx,
Kevin.
Message 8 of 10
Jeff_M
Here's the zip I made back in September, I think it was prior to making any edits.
Message 9 of 10
Thx Jeff .. is there any chance you can attach the sln file from the parent folder?
Message 10 of 10
Jeff_M
Here is the sln file. Remove the .txt extension...
