Alinment: total length multiple alignment & LENGTHEN (total length) an alignment
neam
Message 1 of 15
neam
Hi everyone
How can we calculate the sum of the lengths of multiple selected alignments?
How can we change the length of an alignment like LENGTHEN (total length) example command?
Thank you for your guidance.
Replies (14)
Message 2 of 15
neam
Has anyone encountered a similar case?
Message 3 of 15
saqib_tipa
I don't think this is possible even with help of lisp.
If you want to remove portion of alignment you can Ctrl+Click on segments of alignment and delete those Sub-entityies and if you want to extend Alignment, then Edit Alignment Geometry then add some tangents or curves as required. It is easier.
Message 4 of 15
neam
Message 5 of 15
neam
I got a code to increase and decrease the length of a alignment in .NET language through chatgpt.
But I couldn't generate its .dll file (I don't have Visual Studio).
Can anyone help me get its .dll file?
(Autocad Civil 3d 2019)
Message 6 of 15
neam
and also wrote this lisp for me for the total length of the alignments.
Message 7 of 15
Ronny_Jansen
I tested it and it works, I was wondering why it is needed The <cadApp civApp civDoc> declarations are unnecessary
Message 8 of 15
neam
Thanks for reply
Lisp total alignment lengths work fine.
The problem is in a program written in .NET and I need its DLL.
Message 9 of 15
Ronny_Jansen
Message 10 of 15
neam
Dear Ronny
I see but I am not familiar with any programming language other than Lisp.
Is it possible to convert the zipped file sent by the chatgpt to a DLL file?
Message 11 of 15
Ronny_Jansen
I have the same problem, too little/no C# experience, better luck next time
Message 12 of 15
Jeff_M
@neam looking at the c# code, I doubt that it is what you were really looking for. IF the alignment's last segment runs from west to east in a straight line, then it WILL extend it to the east if lengthened, or the last segment is just deleted if shortened. If the last segment is not running west to east, then the end point will just be moved the adjustment length to the east.
I don't want to spend the time to create a .NET project for this unless it is really what you were wanting to do...
Jeff_M, also a frequent Swamper
Message 13 of 15
neam
thanks Jeff_M for attention:
I want to increase or decrease the length of an alignment from its end to the entered value.
Message 14 of 15
neam
Dear Jeff_M
Of course, my wishes are not very important in this case.
The solution that takes the least amount of time and energy from you is acceptable to me.
Message 15 of 15
Jeff_M
@neam we know what you are looking for, you don't need to keep asking. To extend/shorten an alignment is not a simple task and I do not have time right now to work on something like that. If/when someone does have the time and inclination I'm sure that someone will jump in with their offering.
