Alignment Label set style start chainage
yoitsarun
Message 1 of 18
yoitsarun
Hi all,
I want to access start chainage and end chainage of Label set Style through Civil 3D .Net API.
Any ideas?
I can import styles using code. but i didn't see option for start and end chainage:
ImportLabelSet(ObjectId labelSetStyleId);
Replies (17)
Message 2 of 18
Jeff_M
You can get the AlignmentLabelGroupIds from the alignment. Then get the RangeStart and RangeEnd from each of the LabelGroups.
Message 3 of 18
yoitsarun
Hi Jeff, do you have any sample for that. I'm stuck on this.
Message 4 of 18
Jeff_M
Here is one way:
    public class LabelSetRanges
        public string LabelSet = string.Empty;
        public double RangeStart = double.NaN;
        public double RangeEnd = double.NaN;
        public LabelSetRanges()
    public class LabelTools
        public List<LabelSetRanges>RangeList (Alignment align)
            var retval = new List<LabelSetRanges>();
            foreach(ObjectId id in align.GetAlignmentLabelGroupIds())
                var labels = (AlignmentLabelGroup)id.Open(OpenMode.ForRead);
                var l = new LabelSetRanges();
                l.LabelSet = labels.Name;
                l.RangeEnd = labels.RangeEnd;
                l.RangeStart = labels.RangeEnd;
                labels.Close();
                retval.Add(l);
            return retval;
Message 5 of 18
yoitsarun
Thanks Jeff,
Sorry to ask again, how I can add your code to button click code below?
 private void BtnApply_Click(object sender, EventArgs e)
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            CivilDocument doc = CivilApplication.ActiveDocument;
            Editor ed = acDoc.Editor;
            using (Transaction ts = Application.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction())
                foreach (string name in Alignchecklist.CheckedItems)
                    var alignId = alignList[name];
                    Alignment myAlignment = ts.GetObject(alignId, OpenMode.ForWrite) as Alignment;
                    ObjectId styleID = CivilApplication.ActiveDocument.Styles.AlignmentStyles[AlignStyleCombo.SelectedIndex];
                    ObjectId alignmentLablesSetStyleId = CivilApplication.ActiveDocument.Styles.LabelSetStyles.AlignmentLabelSetStyles[AlignLablSetCombo.SelectedIndex];
                    AlignmentStyle myAlignmentStyle = ts.GetObject(styleID, OpenMode.ForWrite) as AlignmentStyle;
                    AlignmentLabelSetStyle myAlignmentStyleSet = ts.GetObject(alignmentLablesSetStyleId, OpenMode.ForWrite) as AlignmentLabelSetStyle;
                    var lineStyleId = CivilApplication.ActiveDocument.Styles.LabelStyles.AlignmentLabelStyles.LineLabelStyles[LineLabelStyleCombo.SelectedIndex];
                    var arcStyleId = CivilApplication.ActiveDocument.Styles.LabelStyles.AlignmentLabelStyles.CurveLabelStyles[CurveLabelStyleCombo.SelectedIndex];
                    var POBId = CivilApplication.ActiveDocument.Styles.LabelStyles.AlignmentLabelStyles.StationOffsetLabelStyles[POBcombobox.SelectedIndex];
                    var POEId = CivilApplication.ActiveDocument.Styles.LabelStyles.AlignmentLabelStyles.StationOffsetLabelStyles[POEcombobox.SelectedIndex];
                    var Markid = CivilApplication.ActiveDocument.Styles.MarkerStyles[0];
                    double s = myAlignment.StartingStation;
                    double end = myAlignment.EndingStation;
                    try
                        myAlignment.StyleId = myAlignmentStyle.Id;
                        myAlignment.ImportLabelSet(alignmentLablesSetStyleId);
                        double eastingstart = 0;
                        double northingstart = 0;
                        double eastingend = 0;
                        double northingend = 0;
                        myAlignment.PointLocation(s, 0, ref eastingstart, ref northingstart);
                        myAlignment.PointLocation(end, 0, ref eastingend, ref northingend);
                        Point2d startp = new Point2d(eastingstart, northingstart);
                        Point2d endp = new Point2d(eastingend, northingend);
                        StationOffsetLabel.Create(alignId, POBId, Markid, startp);
                        StationOffsetLabel.Create(alignId, POEId, Markid, endp);
                        double station = myAlignment.Length / 2;
                        var ent = myAlignment.Entities.EntityAtStation(station);
                        switch (ent.EntityType)
                            case AlignmentEntityType.Arc:
                                AlignmentCurveLabel.Create((AlignmentSubEntityArc)ent[0], arcStyleId);
                                break;
                            case AlignmentEntityType.Line:
                                AlignmentTangentLabel.Create((AlignmentSubEntityLine)ent[0], lineStyleId);
                                break;
                    catch (System.Exception)
                        System.Windows.MessageBox.Show("Error, Please check Alignemnt and Styles", "AUTO ALIGNMENT LABEL", MessageBoxButton.OK, MessageBoxImage.Information);
                        return;
                ts.Commit();
                System.Windows.MessageBox.Show("Alignment Styles Changed Successfully!", "AUTO ALIGNMENT LABEL", MessageBoxButton.OK, MessageBoxImage.Information);
Message 6 of 18
Jeff_M
Does that not work? Do you get any errors?
Message 7 of 18
yoitsarun
Hi Jeff,
I tried to add to my code. But your code is class method. I dont know how to bring that to my code.
Message 8 of 18
Jeff_M
To use it, just create another Class module in the same Namespace then you can call it like so
var alignLabelSets = RangeList(myAlignment);
which will return a list of LabelSetRange objects. You can the loop through those like so:
foreach (LabelSetRange r in alignLabelSets)
   ed.WriteMessage("\nLabelSet named {0} goes from Station {1} to Station {2}.", r.Name, r.RangeStart.ToString("F2"), r.RangeEnd.ToString("F2"));
//or however else you intend to use the stations
I should note that since the Alignment object derives from the Curve object, you can use Curve properties on the Alignment. Thereby allowing you to save some processing time by changing this:
to this:
                        Point2d startp = new Point2d(myAlignment.StartPoint.X, myAlignment.StartPoint.Y);
                        Point2d endp = new Point2d(myAlignment.EndPoint.X, myAlignment.EndPoint.Y);
Message 9 of 18
yoitsarun
now iam getting below error,
object does not contain public instance definition for getenumerator
may be I used your code wrongly?
Message 10 of 18
Jeff_M
Sorry for not testing, or proofreading, what I posted. The following code, placed in 2 Class modules, works for me.
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.Civil.DatabaseServices;
using System.Collections.Generic;
namespace Civil3D_Misc_Commands.AlignmentTools
    public class LabelSetTools
        public static List<LabelSetRanges> RangeList(Alignment align)
            foreach (ObjectId id in align.GetAlignmentLabelGroupIds())
                try
                    l.LabelSet = labels.DisplayName;
                    l.RangeStart = labels.RangeStart;
                    retval.Add(l);
                catch { }
                labels.Close();
            return retval;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using Autodesk.Civil;
using Autodesk.Civil.ApplicationServices;
using System;
    public class RangeTests
        [CommandMethod("testingrangelist")]
        public void testingrangelist()
            var ed = Application.DocumentManager.MdiActiveDocument.Editor;
            foreach (ObjectId id in CivilApplication.ActiveDocument.GetAlignmentIds())
                var myAlignment = (Alignment)id.Open(OpenMode.ForRead);
                var alignLabelSets = LabelSetTools.RangeList(myAlignment);
                try
                    foreach (LabelSetRanges r in alignLabelSets)
                        ed.WriteMessage("\nLabelSet named {0} goes from Station {1} to Station {2}.", r.LabelSet, r.RangeStart.ToString("F2"), r.RangeEnd.ToString("F2"));
                catch { }
Message 11 of 18
yoitsarun
Thanks Jeff,
I tried this code.
It is not changing in the Labelset properies.
                        try
                                r.RangeStart = 100;
                                r.RangeEnd = 200;
                        catch
but message showing the changed chainages:
LabelSet named Alignment Geometry Point Label Group goes from Station 100.00 to Station 200.00.
LabelSet named Alignment Station Label Group goes from Station 100.00 to Station 200.00.
and the Labelset name is incorrect in the message.
Message 12 of 18
Jeff_M
The example I showed just GETS the values and prints them out. You didn't say you wanted to change them.
In your main code you can just do something like this (not tested but should work):
            foreach (ObjectId id in myAlignment.GetAlignmentLabelGroupIds())
                var labels = (AlignmentLabelGroup)ts.GetObject(id, OpenMode.ForWrite);
                try
                    //make sure you use valid values
                    labels.RangeStart = 100;
                    labels.RangeEnd = 200;
                catch { }
Message 13 of 18
yoitsarun
Thanks Jeff,
I tried it but nothing happening.
Message 14 of 18
Jeff_M
Please zip up your project and post it here.
Message 15 of 18
yoitsarun
Jeff, zip file is attached.
Message 16 of 18
yoitsarun
some error, please find zip file here
Message 17 of 18
Jeff_M
I know this is a work in progress so I won't comment on the other things that need to be addressed other than you should modify parts of the code to only run when the proper radio buttons are checked. These changes to the range portion now allows it to work:
                            try
                                labels.RangeStartFromFeature = false;
                                labels.RangeEndFromFeature = false;
                                labels.RangeStart = myAlignment.StartingStation + Convert.ToDouble(StartChTextbox.Text);
                                labels.RangeEnd = myAlignment.EndingStation - Convert.ToDouble(EndChTextbox.Text);
                                //ed.WriteMessage("\nLabelSet named {0} goes from Station {1} to Station {2}.", labels.DisplayName, labels.RangeStart.ToString("F2"), labels.RangeEnd.ToString("F2"));
                            catch { }
Message 18 of 18
yoitsarun
Thanks Jeff, Finally it is working .
Sorry i wasted your time. I didnt mentioned what i want in the topic.
Many thanks for helping me.
Please guide me, I want to explore more in .net.
