Alignment.Create Method - AlignmentType, where to set?
martin.folber
martin.folber
Hi guys,
we got into big trouble. We are trying to create RAIL alignment (just one curve) using API method and there is no possibility to set Alignment Type... So please could you advice me how to do it. We need Rail because of cant... The way using corridor is crazy...
Martin
joantopo
Have you calculated Superelevations previously?
Maybe is a constraint and you cannot do that if your alignment already has Superelevations.
In Civil 3D, if you try to change the type of an alignment to "Rail" and this has Superelevations, it appears a dialog box about this.
You could remove all SuperelevationCritical Stations if they exists before changing this alignment to Rail type.
The reason is because Rail Alignments have their own Superelevations Assistant.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
Jeff_M
Joan, the AlignmentType property is Read-Only in the .NET API and it's not even available in the COM API.
martin.folber
Hello guys,
I got response from Autodesk support, there is no API support for that 😞
Martin
Can you use this method to create alignment?
Specify AlignmentType here.
王磊
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
