Add Part Family
Add Part Family
Message 1 of 16
Add Part Family
see attachment. i am trying to add a "part family" to our existing SAN parts list. we would like to add "VC" (vitreous clay). it would have the same pipe sizes as the "PVC" pipes in our list. i realize it has to be done with part builder which i have used before to add pipe sizes to an existing part family but have never added a new part family.
Replies (15)
Message 2 of 16
Civil3DReminders_com
I did a video here on doing this for a different name: http://blog.civil3dreminders.com/2009/04/welded-steel-pipe-part-family.html
It should be similar for what you are doing.
Civil Reminders
http://www.CivilReminders.com/
Message 3 of 16
rene_newton
i click on the link but there is no video?
Message 4 of 16
https://youtu.be/qeRXRxELvdQ
Civil Reminders
Message 5 of 16
how do you get the "create GUID" dialogue box to open up when you go to "PartID" at 1:16 of the video?
Message 6 of 16
From Visual Studio.
You can find other programs that create them, like InnoSetup.
Here is a GUID that I created that you can use: {BA8F7656-A8FC-9F43-4930-324A51B99812}
Civil Reminders
Message 7 of 16
installed Visual Studio. got the "create GUID" dialogue box. when i choose "copy", and "New GUID" it doesn't change the code in the XML Notepad file?
Message 8 of 16
so i can just go in and manually change the code to whatever pops up in the "Result" field of the "create GUID" dialogue box? in your video i noticed it changed automatically.
Message 9 of 16
Yes. I may have been using Ctrl+C and Ctrl+V to copy and paste the value.
Civil Reminders
Message 10 of 16
tried using the code the program generated and the code you sent me but the new part family does not show up in part builder? i did the catalog regen and catalog test, rebooted the software but nothing. maybe it has changed since you created this video. i an running 2016. the file is in C:\ProgramData\Autodesk\C3D 2016\enu\Pipes Catalog\Metric Pipes\Circular Pipes
Message 11 of 16
Are there any error messages at the command line or in event viewer or in the refresh dialog?
Civil Reminders
Message 12 of 16
no errors at all. i've attached the file. i did the same as you, copied one of our existing pipes (PVC) and made the changes as per your video.
Message 13 of 16
It looks like something messed up the values of the top of the file. I got this to work:
<?xml version="1.0"?>
<LandPart desc="Part Table" version="1.0" xmlns:xlink="http://www.w3.org/1999/xlink" fixColumn="C1">
  <ColumnConstView desc="Parameter-driven Display" id="CCV1" viewKey="3d" viewName="AeccPartRecipe" pathsRelativeTo="Table">
    <Images>
      <Image>
        <URL xlink:title="Part Reference Image" xlink:href="AeccCircularVCPipe_Metric.bmp" />
      </Image>
    </Images>
    <Recipe>AeccCircularVCPipe_Metric.dwg</Recipe>
  </ColumnConstView>
I had to close the dialog box and restart for the part to be in the list.
Civil Reminders
Message 14 of 16
so do i just open the file in notepad and replace the top part with what you've sent me? i have never done this before. when you say "restart" do you mean CAD or my whole system?
Message 15 of 16
i replaced the coding with what you sent and it works great. thank you very much for your time and help!
Message 16 of 16
Here is a video for next time.
https://www.youtube.com/watch?v=6ov43G4XXBI
It shows fixing the XML by comparing it to one that is working to try to find out what syntax is wrong.
Civil Reminders
