We've just completed a technical support case for a fairly complex static mixer. The scalar mixing algorithm seemed to work very well. This application involves a high ratio in the volume flowrates of the 2 fluids being mixed - nominally 1000:1. That should make it more difficult to solve accurately than cases where the components are in closer proportion. I was originally concerned about the mass balance working out, but that wasn't a problem at all. However, there was one issue that did concern me. At convergence, there were spurious zones of high additive concentration which appeared in the boundary layer near the discharge end of the device. These were actually increases in additive concentration from the values at points upstream. Entropy always increases, and there is no physical basis for these. Fortunately, they didn't distort the results significantly, but they did risk undermining the credibility of the results with the client. Until the issue was resolved, I was concerned about possible solution inaccuracy.
AutoDesk tech support put a huge effort into working this case, and eventually determined that the spurious zones would disappear if the scalar mixing solution control was relaxed, and the case was run for 1000 or more iterations beyond initial convergence. That is not a grand work around for a model with 18 million elements. Even with 24 cores, it was taking 2 weeks to achieve initial convergence, and the client was unwilling to pay additional fees for cloud resources. But it's better than starting out with tight control, and taking many more iterations to achieve final convergence.
I propose the following potential solutions:
1) Set an absolute or adjustable control in the case setup which prevents or limits the formation of spurious concentrations (reverse diffusion),
2) Make allowance for automatic on-the-fly adjustment of the scalar solution control when it senses the formation of spurious concentrations, or
3) Assess how scalar mixing is handled in the boundary layer, and determine if there something different in the algorithm there which can be revised to avoid formation of these regions. In the bulk fluid throughout the rest of the model, the progression of phase concentrations was very credible at convergence.
