Hi all,
would be great if the graphical custom result quantity feature could be extended also for custom probe monitorings like in other CFD-codes...
Meaning:
-Probes should be defineable by points, faces and volumes.
-Need of averaging, summation and integrals of probes (area-weighted, mass-weighted averages, surface integral, etc...)
-Including custom equation settings for probe handling as monitoring with plotting option
-Displaying the equation results for each iteration / timestep as diagram and possibility for export
E.g. Pumps: I want to define a head equation directly from pressure probe inlet and outlet as equation in CFD. The same for torque, power, efficiency, etc. (in general for each thinkable physical value and equation). Results could then be directly exported as csv-file...
kippo
