Change Units without having to Save out a Support Share File
Currently, if you want to change your units, when you already have results, you need to use a support share file.
It would be a better workflow if you could change your units in your active design study even if this had to delete the current mesh and results.
1 Comment
ryan.arnaudin
Status changed to: Accepted
