Dear Community,
My problem is the following. in Autodesk CFD 2018 Wrap Surface i generated a model, which i ran a Steady State simulation. At the evaluation in the results every mode works as expected (Iso Surface, Plane, Traces), except the Wall Calculator. When trying to run the Wall Calculator i get the following error message. What can be the problem?
Thanks!
Strange one as this was an old issue that should not be present in 2018 - saying that I think we need to be sure we are seeing the same thing.
Might you be able to share the support file (CFZ) with us so that we can check it out?
Hello, I had the same problem.
I attached a zip file. I hope you could solve this problem.
If you are doing various things with "Wall calculator", you will get the same error.
@Anonymous
Hi, I just saw your post. The person you were replying to is no longer available... do you still need help with this topic?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
