Water Hammer Arrester Simulation
Message 1 of 8
Good Evening Guys.
I got a water hammer project. There seemed a problem. This software found an error while the solve applied. The error notification: Dissimilar Fluids (Two different fluid parts are touching. Check material assignment to ensure that all contacting fluid parts are assigned the same fluid material).
I ensure that there are no touching two fluid parts. To inform you this problem, I attach the print screen.
Hasan
Replies (7)
Message 2 of 8
Jon.Wilde
Do you have water and air touching? If so, that will explain the error, as you cannot do this 🙂
Message 3 of 8
No, there was no touching air and water.
Message 4 of 8
matt.bemis
Hi @Anonymous,
Perhaps you can remove and then reapply your material properties? Then check if you get this error message again. Feel free to attach your support file (.cfz) here. I am happy to take a look at your model.
Matt Bemis
Technical Support Specialist
Message 5 of 8
Hai @matt.bemis
Here my water hammer arrester simulation.
Please give me some advices due to the beginner.
Thank you for your reply.
Hasan
Message 6 of 8
Hai @matt.bemis
Hasan
Message 7 of 8
@matt.bemis@Jon.Wildesorry for replying you again.
This is my cfz file.
Hasanal
Message 8 of 8
matt.bemis
Hi @Anonymous,
I had a look at your CFD project and it looks like you are no longer facing the issue of two different fluids touching. I opened your project and hit solve and the model worked without issue. I suspect either you removed and then reapplied the materials or maybe changed the setup a bit in CAD.
Glad to see your project will solve now.
Matt Bemis
