Wall Forces at cylindrical structures
as I am writing my master thesis I am also working with Autodesk CFD. I want to get some surface results around cylindrical structures in air at different Reynolds-numbers (keyword: karman vortex street). I run simulations with a 2D cylinder (d=30mm), transient, sst k_omega with time steps around 0.0002s.
For the c_p values (pressure value in the front) the results seem to be alright. Now I would like to measure c_d/c_f (force value at the whole structure in one direction). I tried the Wall Calculator (for Fx) and I'm also working with the Flags "Wall_force_History" and "Resid_bdry_force_calc" to get the wall function over time (to get Fy(t)). Unfortunately the results don't match (for the last time step). I also tried different simulations.
My questions:
  1. What is the difference and which are correct?
  2. Is there another way to calculate the forces on the structure?
  3. Can I somehow get the flag-files to make modifications or write my own? I can't find them in the Autodesk CFD folder.
Thank you very much
Jon.Wilde
Looks like an interesting project, feel free to share some images or videos once you have it run out!
Could you re-ask your first question? Not sure what you mean.
The Wall Calculator should be OK here I think
I don't think you can modify the flags but you could use the API, it depends what you are looking to achieve though?
Jon
Hi
to the first question: the results of wall_force_history (.csv file in project folder, with flags "Wall_force_History" and "Resid_bdry_force_calc") and the results of the Wall Calculator in the programm itselts differ in some simulations. But I am working on this, maybe I have to refine some meshing, timesteps or the like.
With the two mentioned flags I get the csv-file but there are empty rows and text in it. I would be nicer to just have the values over time to look at it in excel. API might be a solution, but it would be easy just to chance the wall_force_history flag.
If I get so good and reliable results I will post them.
So I did some more simulations to find out if the wall-forces of the wallCalculator (last step) and of the.csv-file (last entry), written by the flags "Wall_force_History" and "Resid_bdry_force_calc" are alike. It seems that the reynoldsnumber has an impact. With Re=10^7 the results are the same - for Re<10^5 the results differ up to a factor 20.
My simulations parameters are:
Circulare shape (diameter: 3mm, 30mm, 3000mm)
Inlet: u = 1 - 5000m/s, outlet: pressure, sides: slip
Mesh Refinement at the structure - meshsize 2mm - 0.2mm
No. of Layer 10-15, Layer enhancement 1.5
ADV 5
Turbulence model: k-omega SST
Steady state
Around 2500 iterations
Simulation, which did have the same results:
D = 30 mm, u = 5000 m/s, mesh: 2mm-0.2mm     --> Re = 10^7
D = 3000 mm, u = 50 m/s, mesh: 2mm - 0.2mm     --> Re = 10^7
D = 30 mm, u = 10 m/s, mesh: 2mm BUT k-omega SAS     --> Re < 10^5
Simulation, which did NOT have the same results
D = 3mm, u = 50 m/s, mesh: 2mm-0.2mm     --> Re = 10^5
D = 30mm, u = 50 m/s, mesh: 2mm-0.2mm     --> Re = 10^5
D = 30mm, u = 1, 5, 10, 20, 30 m/s, mesh: 2mm     --> Re < 10^5
Till now I haven´t done any simulations with around Re=10^6...
Do I still have any mistake in my simulations? How do the flags "Wall_force_History" and "Resid_bdry_force_calc" calculate the WallForces?
And I did some more simulations - same setup but different turbulence models.
Results:
The k-omega models RC (both) and the k-omega with the flag "sst_new_iwf" gives with all re-numbers the same results for the WallCalculator and the WallForceHistory in the same simulation. The models k-omega, k-omega DES and k-omega SAS just have the same results with really high re-numbers.
This brings me back to my question:
What it the difference between getting WallForces of the WallCalculator and the WallForceHistory in the same simulation??!
As i would think the WallForceHistory just recodes the results getting of the WallCalculator, BUT this seems not to be the case!
