CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Venturi type pressure boster
12 REPLIES 12
Message 1 of 13
542 Views, 12 Replies
Hi i am trying to increase pressure (static and/or total) through venturi tube.
Is it cnvenient to verify results ?
Many thanks and BR.
Many thanks and BR.
12 REPLIES 12
Message 2 of 13
Message 3 of 13
Message 4 of 13
Jon.Wilde
Jon.Wilde
Is this different to your other thread?
Your model is under constrained, you must properly define what is happening at the inlet so that CFD can define the density.
Ideally, a Total Pressure, Mass Flow rate and Temperature, here is a link explaining how to calculate them.
Then you need to assign a Total Temperature in the Solve window also.
I think I said this before but please consider running a 2D axisymmetric analysis, no need to spend time in 3D here I don't think 🙂
Message 5 of 13
in reply to: Jon.Wilde
Is this model ok ?
inlet 1 atm static/gage.
outlet 0 atm static/gage.
the shape is very simple.
no complex curves/edges.
I've attached alsi geometry file
Stoyan Nikolov.
BR.
Is this model ok ?
Stoyan Nikolov.
BR.
Message 6 of 13
Jon.Wilde
Jon.Wilde
Not yet, no.
You need to assign the conditions I explained above 🙂
Does that all make sense?
Not yet, no.
Message 7 of 13
You mean to set it as picture here ?
Yeah i've did it .
inlet static/gage 2 atm
outlet static/gage 0 atm
No. Is it ok to change it for me.
I am trying to make set up as simple as possible and i am using CDF since 1 week.
Currently i would like to use the most basic config.
I've put temp around 26 degrees Celsius.
under compressible option in the Solve dialog window.
I set compressible flow.
Yeah i've did it .
Message 8 of 13
That is my last setup
inlet 130 m/s
outlet 0 atm static gage
inlet 130 m/s
Message 9 of 13
also attached files.
Message 10 of 13
Jon.Wilde
Jon.Wilde
There is not really a simple approach to doing this, CFD simply will not give you the right results without a properly defined inlet - it needs to know what the exact air properties here are.
Are you comfortable calculating what I shared?
If not, let's do it step by step:
  1. Do you know the flow rate or do you need CFD to calculate this?
  2. How is the device fed, where does the air come from?
Message 11 of 13
inlet 2 atm static/gage
outlet 0atm ststic gage
inlet is the left side.
red painted side on the pictures
Message 12 of 13
inlet on the left side in this particular geometry
you can find it attached also
It also is very simple
no complex shapes/curves
cones and cylinders
cones and cylinders
Message 13 of 13
Jon.Wilde
Jon.Wilde
Might I ask you to stick to one thread? We have three now for the same model.
You need to define this better, it simply will not work with what you have assigned.
At the inlet, you must calculate the Total Pressure and the Temperature.
You also need to define a Total Temperature in the Solve window.
Please answer some of the questions I posted above or I will be unable to help further.
Jon
Jon
