Hi i am trying t build CFD simulatin of venturi pressure booster.
As you see in the picture bellow the pressure in the middle is lower than pressure in both ends.
I am trying to make simulation with higher than input pressure.
The section in the middle will have bigger diameter.
Is it possible ?
BR.
Hey, welcome to our community!
I am not sure I understand your question yet though, are you still planning to model a venturi with a lower diameter at the mid point than at the inlet?
And then you wish this mid-point to have a higher pressure than that of the inlet also?
Jon
Thanks .
I plan to use higher diameter in the middle in order to boost the inlet pressure ?
The opposite from the picture above.
Best regards.
Stoyan Nikolov.
OK, that makes more sense. Higher pressure, lower flow.
Is that what you are looking for?
Yep . Trying to increase input pressure.
With venturi.
Input on the left side , higher pressure in the middle (greater diameter), discharge on the right side.
