- Mute
- Permalink
- Report
I'm trying to simulate the flow of a polymer and I want to see the velocity magnitude in general and also, determine the residence time with the Traces option. However, I assigned a Mass flow rate of 350 kg/h and a pressure of 170 bar at the inlet with 0 psi pressure at outlet.
Running the simulation with a time step of 1s I see the velocity magnitude in a plane (and looks fine), but when I add traces, they don't go from the inlet to the outlet.
Also, I don't understand why there's a huge difference in velocity in the initial length of the inlet and then it goes down. The velocity value seems very unreal, since the mass flow is 350kg/h...
Boundary Conditions:
Traces issue:
Can anyone help me and does anyone know what am I doing wrong?
(I hope you help me Fred :D)
