Message 1 of 16
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All,
I started to face a physical problem in CFD modelling with inventor 2018.2, and appreciate any help from you.
Regarding the torque calculation, I wanted to ask you about my problem. I am running a simulation for an impeller to drive air (suck it) and discharge it through air ventilation unit. I use rotating region material type with RPM. the problem is i don't get the torque calculated and it gives me values zero when I try to calculate it using wall calculator or reviewing the rotating region results or even by using the API tool using Add-Ins. Any help would be appreciated please...
Many Regards,
