The error message happened when concerting a imported geometry happened
Message 1 of 10
When I  loaded a geometry, the error message of failing to convert the imported geometry into an analytical model happened.
Please teach me how to load it.
Replies (9)
Message 2 of 10
Jon.Wilde
This probably means that there is something strange going on within the CAD model.
Which CAD system are you bringing it in from and are you using the CFD button within it?
Have you also tried the Model Assessment Toolkit from CAD?
Jon
Message 3 of 10
Thank you for your reply,but
I' m sorry because I coudn't know what to tell you.
I have Inventor. I only used AutodeskCFD 2018 to open the file(.cfdst).
Message 4 of 10
Jon.Wilde
OK, this sounds strange.
If you have the model in CFD already then you would open the cfdst. You said it failed so you should not have this yet?
If you are still trying to import it, you would be importing the CAD from Inventor.
Did you try launching into the Model Assessment Toolkit from within Inventor?
Please could you share a Screencast  (video) of the process you are following so that I can try to assist? Right now it is not clear what you are doing.
It sounds like you have a problem with the CAD model and need to fix it, once I see a video it might be easier to start this process 🙂
Jon
Message 5 of 10
Thanks for your reply.
I was sorry for not telling you my trouble well.
I have the CFD but I could't open the cfdst file by using it.
I couldn't  operate the Autodesk screen well . So I upload  computor screen processes  below by the time the error message comes out.
when opening the cfdst file.pngwhen opening the cfdst file 2.pngwhen I opened the cfdst file.png
failed to convert the imported geometry to an analytical model.
Takashi
Message 6 of 10
Xiaojin.Zhang
Autodesk Support
Autodesk Support
Hello @Anonymous,
Can I ask you where dose this .cfdst model come from? Did you create it yourself?
Were you able to open it before?
Can you compress this entire folder as a .zip file and send it to us?
Thank you!
Xiaojin Zhang
Message 7 of 10
Hello Xiaojin Zhang.
Thank you for your reply.
I made the cfdst file by saving when experimenting a tutorial and following it on Autodesk CFD 2018.
Takashi Inoue
Message 8 of 10
Xiaojin.Zhang
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for the information. I have seen a similar issue on a Korean customer. The Korean customer could not open the .cfdst file if the design name contains Korean characters.
Can you try to create a new model without any Japanese characters and open it again?
Thank you!
Xiaojin Zhang
Message 9 of 10
I've solved this problems a little.
The file could be opened when I changed my user account to old one.
I think this problem was caused by something like administrator authorization.
Do you know the way I open the file through a new account ?
Message 10 of 10
Xiaojin.Zhang
Autodesk Support
Autodesk Support
Hi @Anonymous,
I don't know if it would help. I suggest you to try to get full control of the folder for your new account in which your model is saved in.
To do this, right click on the folder and select Properties.
Xiaojin Zhang
