Surface Wrapping Error
dherna6
Message 1 of 10
dherna6
I am new to Autodesk CFD and am trying to surface wrap a model. However, after adjusting the external volume and resolution factor to the desired values and clicking surface wrap I receive an error. See image below.
Replies (9)
Message 2 of 10
marwan_azzam
Hello @dherna6 ,
Since we don't have your model we really cannot answer your question.
Two options:
1- we take guesses and hope for the best.
2- you post your model and we try to figure out the issue.
Marwan
Message 3 of 10
dherna6
This is the model file, I am currently using.
Message 4 of 10
marwan_azzam
Hello @dherna6 ,
Since I don't have Solidworks I did the following:
1- Open your Solidworks file in Inventor
2- Save it as a step file
3- Open step file in CFD surface wrap environment
4- Set the size of the external volume
5- generate surface wrap.
I had no issue doing any of that. Attached is the step file as well as the zipped CFD support share file.
I used step format so you can open the same file on your end if you needed.
Marwan
Message 5 of 10
dherna6
Got it, thanks!
Message 6 of 10
Adrien_JASSELAIRE-BLANCO
Community Visitor
Community Visitor
Hello, i have the same problem. Whatever i put in autodesk cfd (simple cube, the modele in this topic ect...) i try diferents type of file (.obj, .skp, inventor ...) he can't generate the surface wrap with the error in the first message.
I give you the real 3d modele i want put in autodesk cfd.
Message 7 of 10
nurselisanli8
Observer
Observer
Hello Mr.
I have the same problem, I try to make your solution but it didn't work. I'm trying to import from SketchUp. Can you help me too? I tried almost everything on that but I always got the same error "surface wrapping error". Ihave 3 different models. If you have time, please answer me. I don't really have any choice but to do this in a very short time. I check my models, they are great in anyways. I don't understand what is the problem and how can I generate a wrap.
Message 8 of 10
dherna6
Unfortunately, I was unable to figure it out using Autodesk. I ended up using Ansys Fluent and that worked out much better.
Message 9 of 10
nurselisanli8
Observer
Observer
I have to use CFD for wind comfort analysis. What should I do with this models ? I convert them into dwg, stp, obj. It didn't work. Do you have any suggestions?
Message 10 of 10
marwan_azzam
can you share the step file with us?
Marwan
