When I use Obj, Stl, Sat, SKP and etc... file formats surface wrap doesn't work and CFD hangs 😞 why this useful option didn't work clearly?? because we use different modeling software and CFD shows it can import any file formats that mentioned above but when I use CFD hangs 😞
here I attached my SAt file that exported from Revit and FBX that exported from skecthup.
Best.
Best.
Here is STL file that exported from Sketchup and error shows in CFD, and when I use wrapping CFD hangs:( the screenshot in attachments.
STL models can be imported directly into Autodesk CFD, but this workflow assumes a solid model. CFD also checks the representation for proper connectivity - meaning that the model is "water-tight."
The surface wrapper is similar in that a solid model is assumed.
