- Mute
- Permalink
- Report
Getting slightly frustrated here...
All of a sudden CFD just stopped being able to run my solves. I'm doing all setup in the exact same way, tried a few different models that worked previously, there's like 100 GBs of freespace on the computer. I don't get it.
Mesher process started...
Meshing override: Tets or triangle elements enabled for boundary layer.
Loading model...
Loading mesh sizes and constraints...
Meshing...
Surface meshing... generating surface mesh
Surface meshing... smoothing surface mesh
Volume meshing... creating volume mesh
Volume meshing... optimizing volume mesh
Volume meshing... smoothing volume mesh
Mesh contains 311142 nodes and 1688707 elements.
Performing mesh quality check...
Saving mesh...
Meshing completed.
Updating model database...
Model database updated.
Updating mesh database...
Mesh database updated.
Building solver model file...
Solver file written.
Initializing ...
Control file processing complete
Check Out basic License: Successful
Authorization verified
Processing input ...
Mesh input complete
Processing results input ...
Results input complete
Processing BC input ...
Computing restart BC data ...
Calculating BC data structures ...
Calculate wall distance for 148239 fluid nodes
Wall distance calculation done in (0 + 1) seconds. Max distance = 3.11078
BC data structures complete and saved
Analysis Initialization Complete
Input processing complete
** FINITE ELEMENT SUMMARY FOLLOWS...
338683 Total Nodes, 148239 Fluid Nodes , 190444 Solid Nodes
1688707 Total Elements, 778704 Fluid Elements , 910003 Solid Elements
3 Inlets 1 Outlets 0 Unknowns
*********** ANALYSIS STARTED ***********
CFD2 launch using 1 machine, 1 processes, and 2 cores was unsuccessful
