- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm having some problems running a solar heating simulation.
I've already reviewed the AEC tutorials, and I've been trying to get something similar to work.
The thing is, I have an internal natural convection problem due to solar heating with a window. However, when I input the transparent BC to the external surface of the window and I try to run the analysis, it terminates due to "having put a transparent BC on a material with a transmissivity = 0".
I don't know if I've been doing something wrong, because I have selected the "Solar Window" material from the Autodesk Default Material List.
I ran the simulation without the transparent BC, however, no radiation energy seemed to have been let through the window.
Also, I noticed that the value of Transmissivity for the Solar window condition, is shown to be 0 (when I click on the list of properties while assigning the material to a solid). Is that the reason why I'm getting this error?
For the rest of the model, I assigned a custom steel material with a solar wall transmissivity condition. This is supposed to be heated by the sun radiation.
Can you help me with that?
Thank you,
Roberto
