simulation error
simulation error
simulation error
Hello Autodesk community
Recently, we have encountered some problems with CFD. two models, (tri wing) (Bern 1-2-2) haven't been working. When we try to run the simulation, it says "loading file", and never does anything. I've let it run for upto 48 hours, and no result.
I've attached the files, see if you have any luck.
Please help!
Thanks!
Vishakh
Amal.C
Hi @Anonymous,
Thanks for reaching out to Autodesk Community 🙂
I understand that you are not able to get through the message "loading file" when trying to launch your simulation in CFD.
Would you please share with me the support file (.cfz) that did not work on your end?
Amal
Amal Cheikh rouhou
I didn't get a support file, all i got was "Reading Model File"
I attached a screenshot
You need CFD 2017 to open Inventor 2017 files... If you havent it, export to ACIS or STEP to get it into CFD.
I don't think so, because another file we made, made in inventor 2017 worked in CFD 2016. Is there anything else that could be the problem?
