Simmetry after fill void
One way to simulate this air blower is build surfaces up and down, and then fill void.
The massive number of holes creates a huge mesh. This model is symmetrical in two planes and it's possible to get results only studying a quarter.
If I import only a quarter of the model from PTC Creo, how is the way to fill the void? It's possible?
If I create a surfaces, CFD don't recognize them.
Jon.Wilde
You can and absolutely should do this (great approach!) but it needs to be done in Creo. Use a couple of blocks to seal the model off. If you bring through a hollow but sealed model, CFD will fill it for you automatically, easy 🙂
I tend to make the inlet and outlet extensions solids in CAD too, then just make them a fluid in CFD.
Check out resistances too, a different tactic that could be useful.
Hope that helps,
Jon
