Running Multiple Scenarios Simultaneously on One Computer
Hi All,
This is a long shot, but I was wondering if there was a way to run simulations simultaneously on one computer. The computer I have is miles ahead of anything else avaiable on the network, and has 12 cores. I know CFD runs on 2^n cores, so 4 are wasted right now, so I was wondering if there was a way to split to processing power through just one computer, since it will still be better than remote solving to another computer.
If I use the remote solver (guidelines link below), can I go into the cfdserv application and specify the same computer, but one as 4 cores and one as 8 cores?
http://forums.autodesk.com/t5/Autodesk-Simulation-CFD/Setting-up-Remote-Solve-Fast-Track/td-p/321199...
I assume not, given the IP address is the same, but I figure I'd ask.
Thanks.
Royce_adsk
Hi Max,
Just as you guessed you can only run 1 job at a time on 1 computer.  I suspect if you tried to do what you suggested it would still get queued.
-Royce
Royce.Abel
Technical Support Manager
Ahh, shame, but thanks for the response.
OmkarJ
Well I use two combinations of cores on the cluster : 8 cores and 16 cores. Now instead of running jobs on 16 cores serially, with one at a tine, I typically run two jobs running parallely with 8 cores each.
I have seen performance improvement of 25% while going from 4 to 8 cores, with anther 25% improvement from 8 to 16 cores. If you do the math, you will realise that two jobs with 8 cores runnign parallely finish in 75% time as that of two jobs running in series with 16 cores.
Now, I am being told that even with two licences, it is not always possible to run two jobs with 8 cores on the cluster simultaneously. In my case, I can so UI often do. As a disclaimer, there may be a risk of erraticv behaviour from cluster while communicating the solution to client. But the economisation is worth the risk.
Cheers
OJ
OmkarJ
Additionally, specific to your case, the two combnations can be 4 cores and 8 cores etc. Even 4 cores running parrallely might be quicker than 8 cores running in series!
