- Mute
- Permalink
- Report
Hello all,
I am using Autodesk simulation CFD 2013 to simulate the naturual air convection of heat sink.
i drew the model in solidworks and imported to the cfd UI, with no problem. simulation and practical results are comparable for heat sink fins, mounted perpendicular to the earths surface.
but the real problem arises, if the fins are inclined to an angle, the simulation results becomes too bad, in other words, the results are crazy.
boundry condition i use are, pressure 0 Pa, on both sides of the air volume and temperature on the lower side of the air volume, the chimney effect. Heat power is given to the surface of the heat sink, where i have made a small extrution to make provision as a heat source. air is set to variable air and also the gravity is assigned. i solve it through mixed length turbulance. meshing is set to automatic meshing. I have the practical results of the same design, I would like to optimize the design. but the practical results and the simulation results are like railway line, they arent coming together. I dont know where am i making mistake.
Practical result is 145 deg C but the suimulation result are somewhere in the range of 3000 degree C. do i need to add some more boundrz condition??..
Kindly help me and thanks for your time.
