09:10 PM
I have constructed a VAWT and started simulation using Autodesk CDF. I have used pick on plane option to get the particle traces.
I have seen a simulation in solidworks where the all the points for which the particle simulation has to be done is evenly distributed from Y-axis plane follows the path of the wind. The number of particle can be controlled. Is there any options to imitate the same in CFD ?
Link copied
