I have constructed a VAWT and started simulation using Autodesk CDF. I have used pick on plane option to get the particle traces.
I have seen a simulation in solidworks where the all the points for which the particle simulation has to be done is evenly distributed from Y-axis plane follows the path of the wind. The number of particle can be controlled. Is there any options to imitate the same in CFD ?
Solved by Jon.Wilde. Go to Solution.
There are more options in 2017, that allows them to be driven from the geometry. I am not sure exactly what you are looking for though, might you be able to share an image?
Sir, In the Photo I attached, the particle comes from a face of the External Volume Generated, then Interacts with the Turbine.
I want to simulate this in Autodesk CFD.
Currently I have to pick points in a sliced plane (Photo attached), the point interacts with the Turbine. Can I achieve the Previously mentioned Results in CFD ?
You can do this, yes. Before 2017 you will need to switch the plane to the y axis and draw an array of points.
In 2017 you can just use the geometry 🙂
Does that answer this for you?
