I have defined a resistance material with the following parameters:
Trough-flow K: Constant: 40
Normal direction 1 and 2: Constant: 1000 (the idea is that air shouldn't flow in this direction)
Permeability: 0
The fluid surrounding it is air.
The pressure drop I get using this material in a simulation is about 40 Pa when a 2.1 m/s flow goes through it.
This is the pressure drop formula provided in the documentation: Creating and Editing Resistances | CFD | Autodesk Knowledge Network
Using it: DeltaP = 40*1.2*(2.1^2)/2 = about 100 Pa.
So I am getting less than half the expected pressure drop.
Have I understood this material/formula correctly? Or is the problem in my simulation?
Thank you in advance,
Pol
