Not the expected pressure drop through resistance material
I have defined a resistance material with the following parameters:
Trough-flow K: Constant: 40
Normal direction 1 and 2: Constant: 1000  (the idea is that air shouldn't flow in this direction)
Permeability: 0
The fluid surrounding it is air.
The pressure drop I get using this material in a simulation is about 40 Pa when a 2.1 m/s flow goes through it.
This is the pressure drop formula provided in the documentation: Creating and Editing Resistances | CFD | Autodesk Knowledge Network
Using it: DeltaP = 40*1.2*(2.1^2)/2 = about 100 Pa.
So I am getting less than half the expected pressure drop.
Have I understood this material/formula correctly? Or is the problem in my simulation?
Thank you in advance,
Pol
marwan_azzam
Please zip the support share file (*.cfz) of your model and share with us.
Marwan
Thank you for taking the time to answer me.
I am attaching the cfz file (sadly without the results as it would be too heavy to post). In it, you will find the filter I was mentioning in the previous post as solid number 43.
In the results I got for this simulation, there were about 7.5 Pa of pressure drop across the filter at about 2.5 m/s. Using the formula provided in the documentation I am obtaining 150 Pa of theoretical pressure drop at this speed.
Have I understood correctly the formula in the documentation? (See original post). Or is there a problem in my simulation?
Thanks again.
Pol
marwan_azzam
Hello Pol,
I would use a uniform mesh on the resistance material with 4 to 5 elements through the flow direction (Z-direction).
Please try that and let us know if you get better results.
Marwan
Hello Marwan,
Thank you for your insight! I will test it and let you know my results as soon as possible.
Pol
I have run some tests and you were right Marwan: it was a meshing problem. Here are my results:
Resistance defined with "constant" method:
 - 1 element in flow direction: 3 Pa pressure drop
 - 4 elements in flow direction: 130 Pa pressure drop
 - 7 elements in flow direction: 125 Pa pressure drop
The last two results are coherent with the formula stated in the first post of the topic.
Other resistance defined with the "free area ratio" method: (different part, results shouldn't be the same as above)
 - 1 element in the flow direction: 3 Pa pressure drop
 - 2 elements in the flow direction: 5 Pa pressure drop
 - 4 elements in the flow direction: 5 Pa pressure drop
So two elements are needed to achieve mesh independence in this second case.
Also, using the "Parts" result calculator provides a  "Resistance Pressure:" value that has nothing to do with the pressure drop result through the part. I don't know what that number means.
Thank you for pointing me in the right direction,
Pol
