not getting a uniform temperature in hot water tank
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, i have water vapor heating a water tank. it's heating it but the temperature in the tank is not uniform. the solution says that the fluid which is being heated is 120 celsius at a certain point and 30 at another point far from the first point. that's not possible in real life. if you are heating a water tank, the temperature inside the tank is gonna be uniform everywhere. increases over time but uniform as increasing. my objective is to find out how much time it will take to heat the water from 10 degree celsius to 100 celsius. i have attached the CFD files in case someone would like to try it. the following picture explains the problem very well. this is after 2 hours of heating. time step 360 seconds. total time 21600 seconds (2 hours)
thanks
