No velocity values
No velocity values
No velocity values
Hello, I am a student and am using the CFD to analyse a F1 in Schools car, but I am having some problems...
The analysis was curring normally, but after the interation 400 the velocity magnitude plan turned all blue, like this the analysis don't have velocity values, and the same happens with the pressure plan.  In the wall calculator, the values of forces it's  absurde to the size of the project( 210mm x 80mm x 60mm). What is can causing this?
marwan_azzam
Hi @Anonymous ,
Did the analysis keep running after that or it stopped?
It might have diverged for some reason. Hard to tell without seeing the model.
Marwan
Hi, keep running, I will send the model.
marwan_azzam
We'll wait for the model.
Images above do not tell what the issue might be.
Marwan
