Greetings,
I'm running a simulation of mixing two moist air, airstreams, classic HVAC mixing box. One stream at 75F, 50% RH and the other at 40F, 60% RH. When using the "moist air" material model, the scalar quantity (which is the absolute humidity) does not project into the mixing box as expected. The results show almost the same scalar value throughout the box, roughly equal to what is expected for the mixture. Sharp gradients in the box do not exist.
If I run the model using a general scalar and the diffusion coefficient for water vapor in air, I get results that I would expect to see with all of the sharp gradients in the box until the two streams can mix.
Is this the expected behavior when using the "moist air" model?
I've attached images from both scenarios.
Thank you.
Cory
