Meshing / gap refinement question
Cnoj
Message 1 of 9
Cnoj
When meshing the heat sink model below the depth of the refinement layers in the air gaps is varying across the model. As all my fin gaps are identical I was expecting the refinement layers in them to be identical. What's causing the variation?
Cad model:
2018-02-13 09_30_45-Autodesk Inventor Professional 2013 - [180206 thermal cap.ipt].gif
I modeled each fin as three solids and each air path as a single solid.
Resulting mesh showing variation in refinement region thickness:
2018-02-13 09_32_03-Autodesk Simulation CFD 2015   180207 Thermal Cap__25mm thk base__ALU 1ms-1.gif
Inventor Pro 2018.3.1
SimCFD 2018
Windows 10 Enterprise
Replies (8)
Message 2 of 9
johnsonshiue
Hi! Is this Autodesk CFD? If not, I am not sure what we can do about it.
Many thanks!
Software Test Engineer
Message 3 of 9
Cnoj
Whoops wrong forum.
SimCFD 2018
Message 4 of 9
Cnoj
OK we're in the correct forum now.
Software is Simulation CFD 2105 v15.2
Thanks.
SimCFD 2018
Message 5 of 9
LKania
Refinement layer length scales are dependent (though not exclusively) on local mesh length scales in order to control element skewness within the refinement layers. Though the fin gap geometry is uniform across your model, the mesh length scales local to these fins are not, hence the refinement layers show some variation as well.
Lee Kania
Message 6 of 9
Cnoj
Which of the four fin gaps in my pic is closest to optimal? I'm using a fully developed velocity boundary condition to move the (fixed density) air and only interested in how well the fins conduct heat into the air.
Jon
SimCFD 2018
Message 7 of 9
Jon.Wilde
I would go with the left hand side, typically the more the better and you can test this by refining the mesh to see if the results change.
Check this out: Mesh Sensitivity Study.
Does that answer your question?
Message 8 of 9
Cnoj
Do you mean more thicker or more in qty?
SimCFD 2018
Message 9 of 9
Jon.Wilde
More in quantity 🙂
