- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone, I'm new to CFD in general and I'm trying to calculate the coefficient of drag of a cube but I cannot get the right value (1.05 at standard conditions according to Wikipedia). I found this Autodesk tutorial about this but no matter what I did I was getting wrong values. I also used the drag formula from that article but its just a rearrangement of the regular drag formula.
Since my mesh was extremely simple, the program autosized it to 10k elements. I tried increasing element count and mesh refinement up to like 200k which did change values but it still didn't give me the correct ones. I tried plugging in the Z axis (upwards) force from the wall calculator on top, bottom, top+bottom and all sides of the cube with the same cross sectional area (10x10cm cube so 0.01m2) and I also tried plugging in the values on the whole "tunnel" but none of that worked. I tried changing the size of the "tunnel" and other things I forgot at this point but all of that to no avail.
This is one of those runs right here with all of the forces on all sides of the cube. Note that the arrows should be the other way around, Z force is greater on the bottom face.
I have attached my projects so it would be great if someone could take a look and tell me what I'm wrong.
Thank you.
