Inlet temperature function
I have a inlet temperature flow which is not constant.
I would like to know whether it is possible to set a variable temperature along the inlet. A way to set a inlet temperature function or at least a way not to set it as a constant value.
Could you help me please?
Sylvain
matt.bemis
Hi @Anonymous,
This is definitely possible. You can set the inlet temperature to be transient. The only limitation is that it has to be a function of time; no other independent variable is available.
Matt Bemis
Technical Support Specialist
Thank you for your quick answer.
I'm actually simulating in a steady way and I need to change the temperature in function on an axis, not in function of the time. So i guess it is not possible?
matt.bemis
@Anonymous,
I was afraid of that. There's no way to make T BC a function of distance. I suggest breaking up the face of the current Temp BC and then increment the temperature as it should be.
Matt Bemis
I think I found:
I will let you know how well this works.
Thank you for your help
Sylvain
matt.bemis
@Anonymous,
Sorry, can't believe I missed that 😕 - Spatial Variation should do it.
Good eye!
Matt Bemis
