How to remove X,Y,Z axis from Autodesk CFD ?
Capture.PNGTrying to remove the coordinate system on the right of the image. Anyone knows how to?
bob.schlosser
This is easy to do.  Go tot the top ribbon and click on the view tab.  Then click on the drop down arrow next to Axes and select what you want shown.
That is for the axis labels. It does not go below 4. I am trying to remove
the arrows shown on the right side of the pic.
bob.schlosser
Click on the arrow by the axis button.  Then unselect the check boxes for the axis you don't want visible.
i can't click on the arrows or the axis
bob.schlosser
Sorry, that's as much help as I can give you.  All I can say is that the axis button in the view tab works as a drop down menu that allows you to turn off the various axis.  It works the same as any other button on the ribbon interface.
The link to this in the help file is http://help.autodesk.com/view/SCDSE/2019/ENU/?guid=GUID-282F9208-7853-4816-B9C6-1241E65E846F
David.Short.
Hi @Anonymous,
Did you manage to solve your issue with Bob's help?
All the best,
David
David Short
Technical Support Specialist, Simulation
