How to export a Revit file to CFD?
grunge1294
Observer Observer
grunge1294
Observer
Observer
Hello friends, I'm a student and I'd like to learn how to use the software but I'm having some troubles related to the exportation of the Revit project to the CFD.
I use Revit 2020 and CFD 2018 so apparently the CFD launch button doesn't show when Revit is not the 2018 version. I tried to use the CFD Configuration Wizard but there's no possibility to tick the Revit software:
I'd like to know if there is a way to export a Revit project to CFD manually or if there is a way to enable the button. Please help me guys!
Thank you for your attention, sorry if there is a mistake in my English!
MichaelSpahn
Revit 2020 and CFD 2018 do not work. Please install CFD 2019.2.
You can export the model to Inventor and then load it as .step into CFD.
You can also try to export your model in revit as .fbx and then load it directly into CFD. I have no experience with this!
Stay hungry, stay foolish!
Viele Grüße,
Michael Spahn
TGA Planer/Konstrukteur
Firmenwebsite | LinkedIn
Ihr fandet einen Beitrag hilfreich? Dann vergebt dafür doch Likes!
Eure Frage wurde erfolgreich gelöst? Dann einfach auf den 'Als Lösung akzeptieren'-Button klicken!
