animate particle tracks
MichaelSpahn
Advisor Advisor
Message 1 of 12
MichaelSpahn
Hello community,
I want to animate particle tracks. I just don't know how. I've calculated the simulator tone with one iteration. If I create several iterations I still don't get a fluid animation.
Stay hungry, stay foolish!
Viele Grüße,
Michael Spahn
TGA Planer/Konstrukteur
Firmenwebsite | LinkedIn
Ihr fandet einen Beitrag hilfreich? Dann vergebt dafür doch Likes!
Eure Frage wurde erfolgreich gelöst? Dann einfach auf den 'Als Lösung akzeptieren'-Button klicken!
Replies (11)
Message 2 of 12
frederic.gaillard.7
you need to set save intervals
Message 3 of 12
MichaelSpahn
What exactly do I have to observe or enter?
Viele Grüße,
Michael Spahn
Message 4 of 12
frederic.gaillard.7
Amination work by frame. Frame need to be saved to have a continous video
http://help.autodesk.com/view/SCDSE/2019/ENU/?guid=GUID-A815C3A3-375F-43EC-95FE-E2669A17DC93
Message 5 of 12
MichaelSpahn
These settings had no effect
Viele Grüße,
Michael Spahn
Message 6 of 12
frederic.gaillard.7
It's normal you set the following :
saved interval 50
solved step 10
solved step need to be higher.
hope it helps
Fred
Message 7 of 12
MichaelSpahn
Hey Fred,
Hey, Fred,
I've increased the levels. But I'm still not getting a result. Where are the individual images stored?
Viele Grüße,
Michael Spahn
Message 8 of 12
frederic.gaillard.7
Hi Michael,
You have to select the appropriate results whether is ''step'' or ''second'' and make sure that these results are smaller than the ''TimeStepToRun''
The saved interval should stored in the solver folder under the scenario name.
Fred
Message 9 of 12
MichaelSpahn
Hello Fred,
I have this in the solver folder
Viele Grüße,
Michael Spahn
Message 10 of 12
frederic.gaillard.7
Hello Michael,
According to your picture t60 and t120 should be present in your animation box. So the setting in your Solver window is correct.
You can add some saved interval by running more iteration (180,240,300...)
Are you able to validate if they are in your animation window ?
Fred
Message 11 of 12
CGBenner
@MichaelSpahn  Did the information provided by @frederic.gaillard.7  answer your question? If so, would you please use Accept Solution so that others may find this in the future? Thank you very much!
Chris Benner
Message 12 of 12
MichaelSpahn
Hello, Fred,
Sorry I didn't get back to you sooner.
I'll have more time next week to consider your proposal.
Thanks for everything.
Viele Grüße,
Michael Spahn
