Help with Centrifugal fan and rotating region
Message 1 of 27
Hey,
Can anyone please help me understand why the solver is failing and also provide any steps to make this study more accurate?
Any help would be appreciated.
Accepted solutions (3)
Replies (26)
Message 2 of 27
KubliJ
Hi @Anonymous
It looks like the rotating region got switched with an air volume. It is assigned to a volume (Volume 35) that encloses an air volume (Volume 39) that encloses the impellers. The air volume that encloses the impellers (Volume 39) needs to be assigned as the rotating region and Volume 35 needs to be assigned as air.
James
James Kubli, P.E.
Please marked this as solved if your question has been answered.
Message 3 of 27
I thought that was what was wrong too and I made the Rotating Region a solid piece and inserted the fan into it. This got rid of the CFD created volume and I was able to set up everything. It still failed as the solver started.
Message 4 of 27
Attached wrong file
Message 5 of 27
Does the rotating region need to be a solid cylinder or a hollow one? @frederic.gaillard.7
Message 6 of 27
frederic.gaillard.7
Solid cylinder surrounded by a fluid material
Message 7 of 27
@frederic.gaillard.7 Please help me understand why this failed
Message 8 of 27
KubliJ
Hi @Anonymous
Take a look at this model. It should run without issue.
James
James Kubli, P.E.
Message 9 of 27
Hi @KubliJ ,
For some reason, I am unable to get any results from your version. Similarly, I tried editing my CAD model per your changes and was unable to get any results even though I left my computer running overnight.
I'd appreciate any help you can provide. @frederic.gaillard.7
Message 10 of 27
frederic.gaillard.7
Hello Aditya,
You use a more recent version than mine, i can not open it. If you want me to have a look please share your step file.
Thx
Fred
Message 11 of 27
Hi @frederic.gaillard.7 ,
No problem, attached Parasolid and STEP file here. Thank you very much!!
Message 12 of 27
frederic.gaillard.7
Hello Aditya,
Your fluid volume who surround your rotating region is empty :
This region must be filled the same as your intlet and your outlet.
Hope it helps
fred
Message 13 of 27
Thanks @frederic.gaillard.7 ,
Was able to see some results.
Message 14 of 27
frederic.gaillard.7
Hello Aditya,
No problem, you can send me your new step file if you want i will run it on my end with the good pratice of the turbomachinery.
Fred
Message 15 of 27
Hey @frederic.gaillard.7 ,
Thank you so much, I really appreciate it. Attached in this post.
Message 16 of 27
frederic.gaillard.7
Hello.
You reproduce the same error.
Intlet and outlet must be complete solid, not hollow prism or cylinder like you have.
furthermore you have a lot of small ''air volume'' around your rotating region, make sure you only have three air region
  1. intlet
  2. impeller housing
  3. outlet
Fred
Message 17 of 27
Is this better?
Message 18 of 27
frederic.gaillard.7
Yes, but try to model the housing in one piece
Message 19 of 27
frederic.gaillard.7
Hello Aditya,
Your making progress, all the the computational domain is filled by a fluid which means all the pressure and the velocity vectorial field could be resolve in this domain, well done !
However, You still have work to do on your impeller.
  1. First thing to do is to close your blade, right now you have air inside your blade, see by yourself : Capture.JPG
you almost there !
Fred
Message 20 of 27
Ok @frederic.gaillard.7 ,
Made the Blades a solid piece.
