Free surface analysis boundary conditions between liquid surfaces
- Mute
- Permalink
- Report
Hey!
I have a question regarding free flow simulations. I am trying to model the water flow through a water dam. For this I have drawn the dam in Inventor and also added parts for water in an assembly and imported them into Autodesk CFD.
From what I have understood there should be parts for both the initial height of the water (the bottom block) and for the height the water can reach to while for example passing through the dam. Both these "parts" are seen below in the picture, they are both chosen to have water as material. The dam is chosen concrete, and is suppressed.
My question is about the boundary conditions(please see second pic). Especially the one between the two blocks. If I choose P=0 in between the two, I get crazy high levels of water. If I choose nothing the analysis stops due to errors. I believe the answer will be obvious to many but I have never done free surface before so would highly appreciate input on this matter.. What is the right way to go with boundary conditions in this case?
