Exporting from Fusion 360 TO CFD
eng.abass5
Message 1 of 11
eng.abass5
Hi there,
I am using Fusion 360 to design the models , but i am not sure how to export my model to Autodesk CFD.
to run a thermal fluid simulation. for example i draw heat exchanger model by fusion 360, and want to
expert the properties of a fluid flow inside this model using CFD.
is this possible and how ?
thanks
Replies (10)
Message 2 of 11
Jon.Wilde
I would export as sat or step.
Then, within CFD, go to 'new' and read it in 🙂
Message 3 of 11
Amal.C
Hi @eng.abass5
Were you finally able to import your CAD model into CFD while exporting it from Fusion as. step or. sat?
please let us know 🙂
Amal
Amal Cheikh rouhou
Message 4 of 11
eng.abass5
Actually this not the point,
But i am not sure if the module that is imported from fusion will have the real properties and if the simulation results true or not , specially if the modul is complecated ?
Message 5 of 11
Jon.Wilde
CFD just sees CAD models as dumb volumes initially - so all properties need to be assigned within the CFD interface.
Does that help to answer your question?
If not, could you rephrase the question as I am not sure I understood.
Thanks!
Jon
Message 6 of 11
eng.abass5
got it, thanks, Jon .
so if i draw for example ..  channels between 2 plates using fusion 360, and open
the file in the CFD , the software can understand that there is a channels or spaces between
the plates, and can let any fluid to flow inside the channels?
sorry i  have other question, if you notes attached photo you
can see some notifications in the left side ( yallow color ), do the mean some thing wrong ?
Message 7 of 11
matt.bemis
Hi @eng.abass5,
Do not worry about those yellow exclamation points. As you can see on the side, it just means those feature do not exist in the CAD therefore the model assessment toolkit skips them.
Matt Bemis
Technical Support Specialist
Message 8 of 11
eng.abass5
Thanks Matt,
sorry, but i have many to ask about.
Now, which is better for modeling mechanical devices like heat exchangers fusion 360 or inventor?
Message 9 of 11
matt.bemis
Hi @eng.abass5,
That is an interesting question :). It's really up to which the user has more experience/proficient with. Both would be fine for modeling mechanical devices including heat exchangers.
Matt Bemis
Message 10 of 11
eng.abass5
Sounds nice, thanky you again Matt.
Message 11 of 11
matt.bemis
Hi @eng.abass5,
Sure! I am happy to help. Good luck modeling!
Matt Bemis
