Difficulties in internal air flow
Message 1 of 12
Thanks to the support team for their great assistance in the forum
In this example below i want to simulate natural ventilation in pyramid room, I set Volume flow rate and temperature for Inlet boundary condition and Pressure for outlet, but in results didn't show me any thing about air flow particles and contours It seems that nothing happens in room. Thanks for checking my file, That I understand where my work is wrong.
Best.
Replies (11)
Message 2 of 12
hello,
please re-check your model, it seems it has lots of problem and check your parameters are those parameters feasible or not?
regards,
Akshay Kumar
Message 3 of 12
Jon.Wilde
Please share a CFZ file (above the place where you ran the model from). This is all we need to open the file - what you shared is still trying to run and does not allow us to see what is going on.
A few thoughts though:
  1. Extend the inlet and outlet out to 5x their width in length - add two parts in CAD to achieve this. A hollow and sealed model will be filled automatically in CFD
  2. What is the initial velocity condition doing? My guess is that it is not needed
Otherwise, I suspect that the issue is how you are trying to view the results as the model looks OK.
Did you run through all the tutorials?
Jon
Message 4 of 12
I want to simulate air coming from outside building into and goes from an outlet, I also tried with the simple cube model attached, and I write my parameters set to simulation in a picture below, In cube simulation, everything goes right but nothing was evacuated from an outlet.
the file format that saves from CFD shows .cfdst, I can't find a .cfz file that you mentioned.
Message 5 of 12
Jon.Wilde
The CFZ file is located a level above the CFDST, or you can save one out from the menu in CFD (Save Share File)
Message 6 of 12
Thanks Jon.
Message 7 of 12
Jon.Wilde
You have applied a glass material over the inlet and outlet, so no flow can move... Are these windows or are they open? You need to have one or the other :) What do you have in reality? Thanks, Jon
Message 8 of 12
Oh, I realized.
Thank you so much, jon.
Message 9 of 12
pardon me, I fix the material problem and simulate again, air flows from inlet but circulated all of them in the room and nothing goes from outlet. It looks like the output does not work or I have a mistake again :))
Message 10 of 12
Jon.Wilde
There are things here that make no sense physically.
Please extend the inlet and outlet in CAD as recommended before. This needs two new cuboids adding. You really need to do this for accuracy, you need developed flow at the inlet and no recirculation over the outlet.
After this and in addition to nice smooth flow, your inlet temp will not be touching the film coefficients (what would CFD guess as the temperature on the bounding edge?). Right now this will cause an issue thermally.
There is flow and it is just very low, is it really only 50m3/min through a box that is 30m x 30m?
If I increase the flow by a factor of 10, it is working (although poorly without the extensions of course):
Message 11 of 12
okay, I understand Volume flow rate and modeling issue but I don't understand Temperature problem and how to fix this problem?
Message 12 of 12
Jon.Wilde
Extend the inlet, then the temp will not touch the film coefficient 🙂
