cyclone separator
cyclone separator
S_May
Mentor Mentor
cyclone separator
S_May
Hello together,
does anyone have experience in the simulation of cyclone Separators for sandblast?
+ inlet DN300
+ sand mesh 80
+ 6000m³ / h
+ outlet DN250
I have finished the assembly but I'm unsure, and would like to simulate in cfd
does that work with air and sand?
I have an example in the Appendix
Model (Inventor 2018) is ilogic controlled, everything can be easily adapted!
copyright S_May
David.Short.
Hi @S_May,
Simulating a cyclone separator should be possible. Here is an article regarding a possible setup for modelling the cyclone flow.
However only disable "Auto convergence assessment" not the entire "Intelligent solution control".
To analyse the behavior of sand in the separator the general approach would be to use massed particle traces in the post processing stage.
I hope this helps a little.
All the best,
David
David Short
Technical Support Specialist, Simulation
S_May
Hi @David.Short.,
Thanks for the answer.. Smiley Happy
