Cloud Solve Error
Cloud Solve Error
Message 1 of 12
Cloud Solve Error
I have tried CLOUD Solve for a few time, and every time I tried it came up as error. The error message is also always the same, which is "Key Used". Here's the full error log :
<20180901T203857 level=err source=getResponse http error code=400 proc=SimJobManager.exe:6376 message="request failed with 400
	DELETE https://metering.autodesk.com/api/auth/v1/ZNEKL9DBXXHG/cfdws/FETHN9GQWTY3?format=json&jobid=V1~H2V2~P~mfg-dsim-simcfd-2019~ZNEKL9DBXXHG~59502b76-0304-4222-a846-30a1af8d7149
	request headers:
		Authorization=OAuth oauth_consumer_key="4f04d20b-f576-4c49-a79c-520df3698d72",oauth_nonce="66ba665889f54479a238b1ae5c4816ea",oauth_signature="x04xC4f32jfArM0cMubEkvfthbE%3D",oauth_signature_method="HMAC-SHA1",oauth_timestamp="1535809136",oauth_token="T5joiUmmeUt5Zbq589wqMqcD%2B1I%3D",oauth_version="1.0"
	response headers:
		Cache-Control=no-cache
		Content-Type=application/json; charset=utf-8
		Expires=-1
		Pragma=no-cache
		x-ads-error=HE1008
		Content-Length=47
		Date=Sat, 01 Sep 2018 13:38:50 GMT
		Connection=keep-alive
	response body:
		{"errorcode":"HE1008","description":"Key Used"}" >
Thanks in advance.
Replies (11)
Message 2 of 12
matt.bemis
Hi @Anonymous,
I am not sure what that log file means. What happens in the user interface? Do you get an error message? What does the simulation job manager show? Does it say the simulation failed on solve? Do you think this failure is model specific? Does the same scenario solve locally?
Matt Bemis
Technical Support Specialist
Message 3 of 12
Thanks for the reply, I don't see any error message in the UI, the simulation manager shows it as "Failed". I haven't tried solving locally but I will try to solve it locally.
Message 4 of 12
matt.bemis
Hi @Anonymous,
Thanks for the update. What is marked as failed in the SJM UI? Upload? Solve? Download? Were you charged cloud credits?
Have you checked the Status file? Check the end of the status file to see if it contains any useful information. Feel free to attach the Status file here. I am happy to take a look at it.
Matt Bemis
Message 5 of 12
Solve is the one with the error, I wasn't charged. How do I check the status file?
Message 6 of 12
matt.bemis
Hi @Anonymous,
It's good to hear you were not charged. The screenshot below shows you where the status file is.
status file.jpgThanks,
Matt Bemis
Message 7 of 12
The button is inactive, but I have tried on other objects and it works. I think that model is just too complex
Message 8 of 12
matt.bemis
HI @Anonymous,
Ok, thanks for the update. You may be right. Feel free to attach a support file and I'll take a look at the model.
Matt Bemis
Message 9 of 12
This is the one I am trying to simulate
Message 10 of 12
matt.bemis
Hi @Anonymous,
I don't know what a .rstl file is. Where did this file come from? Is it a CAD file? Neither Inventor or Fusion 360 can open it up, and it's not native to Autodesk CFD.
Matt Bemis
Message 11 of 12
Wrong file, sorry @matt.bemis
Message 12 of 12
matt.bemis
Hi @Anonymous,
The errors you are facing probably have nothing to do with the cloud. You geometry has very poor integrity. I recommend rebuilding the geometry from scratch, using your current obj as a reference. I recommend using a solid body modeling package like Fusion 360 or Inventor.
Matt Bemis
