CFD simulation for building structures
I am a MSc structural engineering student and i am researching wind loading on tall buildings.
I have decided to use CFD simulation and compare the data to a wind tunnel test and the eurocodes guidance.
Therefore, I need to work out how to create an environment akin to a wind tunnel (i.e the neighbouring buildings etc) and was wondering if there are any webinars you could point me too.
I have exported my robot model to CFD but i do not have any of the neighbouring buildings at present. Can additional buildings be created in CFD or do i have to create them elsewhere.
Lee Hobbs
Jon.Wilde
Hi Lee,
It should be super easy.
1) You need a draw an air domain in CAD (the wind tunnel)
2) All geometry must come from CAD, not CFD
3) In CFD assign a P=0 to the outlet and a velocity at the inlet (you can have it varying with height)
That is about it as a starting point. Then we could look to refine the mesh to improve the accuracy of the results. Maybe shout when you reach this stage?
Jon
Amal.C
Hi Lee,
I would also highly recommend following the instructions listed in the article Wind Loading  as a starting point for your project 🙂
I hope this helps
Amal,
Amal Cheikh rouhou
