CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
CFD Air flow simulation from Autodesk Inventor Assembly
2 REPLIES 2
2346 Views, 2 Replies
I am a beginner with Autodesk CFD, but I want to make an Air flow simulation from an assembly I draw with Inventor 2016.
In the attachment you see some pictures of the assembly. This assembly I want to open with Autodesk CFD 2016, but the program is not responding, and crashes every time I want to load this file. I think the file is too big for CFD because there are a lot of patterns in it. I already tried to export the assembly as different CAD formats, like .stp, .sat and .x_t, and I also tried it with a simplified part.
How can I solve this problem?
Thanks in advance!
Sincerely,
Sam
2 REPLIES 2
Jon.Wilde
Try just a cube, to be sure the issue is model related.
Then, why not read this in using solid block with no holes and use the 'resistance' material to give your parts the right properties?
in reply to: Jon.Wilde
I tried it with just a few cubes, so I draw it in Inventor as one part which respresents the air in the whole system.
This video also helped me to solve the problem: https://youtu.be/PgHeW_zIHao?t=12m55s
Now CFD opens it and makes a simulation.
Thank you very much!
