CFD 2019 - Solve cycle does not complete
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I am having a recurring issue whenever I run a local simulation. After the solver has completed the iterations in solving the problem it seems to become hung. Therefore the job is not logged as complete and the next job in the queue cannot be run. It seems like the simulation manager does not detect that the solver has completed and therefore continues to allocate resources to the solver. The CFDSolver.exe process continues to use processing power and RAM without having any working set delta memory.
I have tried the uninstall - reinstall of the ServerManager as well as deleting the files in the Analyze folder. The same issue recurs. Pressing the "Stop" button also has no effect as it always tries to complete the "last iteration" when there are no more iterations to perform.
This means that I have to constantly "baby" each simulation and manually end the CDFSolver process after each iteration. This is proving to be a massive time-hog so any assistance in this regard will be greatly appreciated.
Best wishes from my end.
The message window reads as follows:
Turbulent Incompressible Flow is ON
Turbulence model: Standard k-epsilon
Intelligent Wall Formulation: ON
Begin Post-Processing Calculations ...
Post-Processing Calculations Done
Begin Post-Processing File Output ...
Post-Processing File Output Done
User stop request sent to server
Stop button selected. The analysis will stop at the end of the current iteration.
